Каталоги для АКПП LoryTP,Trans tar,Alto -PDF
Создавать темы 03-Сен-2024 20:54 | #1 · Автор
Год выпуска: 2006
Версия: 2005-2006
Платформа: Abobe Reader
Совместимость с Vista: полная
Системные требования: компьютер
Язык интерфейса: только английский
Таблэтка: Не требуется
Описание: General Motors
TH125 Transmissions - TH125 (M34) 3T40, TH125C (MD9)
Saturn TAAT - Saturn Transmission - TAAT - FWD 4 Speed
A210, GM MX17 - 3 Speed FWD
TH180 Transmissions - TH180 (MD3) 3L30, TH180C (MD2)
4L40E - 5L50E Transmissions - 4L40E 4 Speed 5L40E 5 Speed (M82), 5L50E (M22) Electronic - RWD
TH200 Transmissions - TH200 (M29) TH200C (MV9)
TH200-4R - TH200-4R (MW9)
MK2, MK5 - MK2, MK5 - Corvette Overdrive, GM Overdrive 4 Speed
TH325 Transmissions - TH325 (M32), TH325-4L (M57) w/ Lockup
TH350 Transmissions - TH350/350C, TH250C/375B
TH400 Transmissions - TH400 (M40) 3L80, TH375 - TH475 3L80HD
4L80E/85E Transmissions - 4L80E (MT1), 4L85E (MN8) - 4 Speed w/ OD
4T40E/45E Transmissions - 4T40E (MN4), 4T45E (MN5) - 4 Speed Turbo Hydramatic
TH440-T4/4T60 Transmissions - TH440-T4 (ME9) 4T60 - 4 Speed - FWD
4T60E/65E Transmissions - 4T60E (M13), 4T65E (MN3, M15, MN7 HD) Electronic - 4 Speed - FWD
4T80E Transmission - 4T80E (MH1) Electronic - 4 Speed - FWD
Allison LCT - Allison LCT 1000/2000/2400 (M74)
Allison AT540 Transmissions - Allison AT540, AT543, AT545
Allison MT/B 640 Transmissions - Allison MT/B 640, 643, 644, 647, 650, 653, 654
TH700-R4 & 4L60/65E Transmissions - TH700-R4 (MD8), 4L60/4L60E (M30), 4L65E (M32)
Powerglide - Powerglide - Aluminum Case
ST300 - Super Turbine 300
TH425 Transmission - TH425 (M40E)
GM Screens/Filters - General Motors Timble Type Screens/Filters
Ford
C3 / A4LD Transmissions - Ford C3 (3 Speed) A4LD (4 Speed)
4R44E thru 5R55E Transmissions - 4R44E(2.3, 3.0L), 5R44E(2.3, 3.0L), 4R55E (4.0L), 5R55E (4.0L)
5R55N/S/W Transmissions - Ford 5R55N, 5R55S, 5R55W
C4/C5 Transmissions - Ford C4, Ford C5 - w/ Lockup
C6 Transmission - Ford C6
CD4E Transmissions - Ford CD4E, Mazda LA4A-EL (4 Speed - FWD)
E4OD Transmissions - Ford E4OD, 4R100 (4 Speed OD - RWD)
ATX Transmission - Ford ATX Transmission
4F27E Transmissions - Ford 4F27E (FN), Mazda J39A (FN)
AXOD/E Transmissions - Ford AXOD/E (AX4S) AX4S-HO Overdrive
AX4N Transmission - Ford AX4N (4F50N)
AOD/E & 4R70 Transmissions - Ford AOD (FIOD) AOD-E (Electronic), 4R70W/4R75W, 4R70E/4R75E
Fordmatic Transmissions - Fordmatic 3 Speed, Iron Case (Small, Medium), FMX
Ford Screens/Filters - Ford thimble type screens / filters
Chrysler
A-500 / TF-6 Transmissions - Chrysler - A-500 (40/42RH; 42/44RE Electronic), TF-6 [A904 (30RH) A998 (31RH) A999(32RH)]
A518/618, TF-8 Transmissions - Chrysler - A518(46RH/RE), A618(47RH/RE, 48RE), TF-8(A727 - 36/37RH)
545RFE & 45RFE Transmissions - Chrysler - 545RFE - 5 Speed, 45RFE - RWD/4WD - Fully Electronic 4 Speed
A404/413, A470/670 Transmissions - Chrysler - A404(30TH), A413, A470/A670(31TH) - FWD
A606 / A604 Transmissions - Chrysler - A606 (42LE), A604 (40/41TE - FWD, 41AE - AWD), RWD (42RLE)
Imports: KM170-177, F4A / AF Tranmissions - Imports: Chrysler(KM170-177), Mitsubishi(F4A-33), Hyundai(AFAF1-AFBF3)
Imports: RFA / V4A51, R5A / VA51 Transmissions - Imports: Chrysler/Mitsubishi/Hyundai - RWD (4Spd)RFA/V4A51 (5 Spd)R5A/VA51 - FWD
BW8 / 12 AMX - Cast Iron, Flash/Flightomatic - Chrysler - BW8, BW12 AMX - Cast Iron, Flashomatic/Flightomatic
BW T35/41/44 & Aluminum Case Flash/Flightomatic - BW T35/41/44 Transmissions & Aluminum Case Flash/Flightomatic
Honda
HONDA - Hondamatic 2/3 Speed
HONDA - Filters & Identification Charts
Mazda
F3A Transmissions - Mazda F3A, Ford Imports - 3 Speed, F3A- Jatco, GM R cars
F4A Transmissions - Mazda F4A-EL - FWD, F4E-III, Ford F4EAT - 4 Speed
G4A Transmissions - Mazda G4A-EL/HL, GF4A-EL - FWD, Ford - G4EAT 4 Speed
JF506E Transmission - Mazda JF506E - FWD - 5 Speed, Jaguar, VW
Mercedes Benz
Mercedes 722.0 to 722.6 Tranmissions - 722.0 to 722.6 5 Speed, Chassis ending 177-123 4 Bolt Pan/6 Bolt Pan, 3-4 Speed
Nissan
L3 / L4 / N4 Transmissions - Nissan L3N71B 3 Speed, E/L4N71 4 Speed, Mazda N4A-EL
RL / RE /R4 Transmissions - Nissan RL4R01A, RE4/501A, RE4R03A - 2/4/RWD, Mazda R4A-EL - 2/4/RWD
RE/RL4F02A Transmissions - Nissan RE4F02A, RL4F02A - 2/4WD, FWD w/ lockup
RL/RN3 Transmissions - Nissan RL3F01A, RN3F01A - 3 Speed w/ lockup
JR403E Transmission - Isuzu, Mitsubishi, GMC, Mazda, Nissan Trucks - JR403E - RWD Jatco Truck
RE/RE4F03/4A Transmissions - RE/REL4F03A Nissan, RL4F03V Sentra, Infiniti G20 - RE4F04A Nissan, RE4F04V Maxima,/Altima, 4F20E Villager/Quest, 4 Speed FWD, JF403E Storm, LJ4A-EL Millenia
Renault
Renault M Series Transmissions - Renault FWD 3 Speed Transaxle - MB1, MJ1, MJ3, 4139, 4141
Renualt A Series Transmisions - Renault, Eagle Premier - FWD 4 Cylinder - AR4, AD4, AD8
Renault DPO - Renault FWD 4 Speed Transaxle - DPO (AL4)
Borgwarner
BW-T35/37 Tranmissions - Borg Warner T35TB, T37TB, Saab FWD
W-T65/66 Transmissions - BrogWarner T65, T66 RWD, BMW Jaguar
BW-T35/41/44 Transmissions - BrogWarner BW-T35, T41, T44 (also in Chrysler section)
Subaru
M41 Transmissions - Subaru - M41, M41A, GUNMA - 3 Speed FWD, 2/4WD
R4AX-EL Transmissions - Subaru R4AX-EL (4EAT) 4 Speed - 2/4WD FWD 1st & 2nd Design
ECVT Transmission - Subaru ECVT Transmission
Toyota
A40 Series Transmissions - Toyota A40 Series RWD - Isuzu, Volvo, Mitsubishi
A340E Series Transmissions - A340E/350E 4 Speed - A650E/750E 5 Speed - A761E 6 Speed (Lexus)
A440 Series Transmissions - Toyota A440F, A442F, Landcruiser - Aisin Warner 450-43LE Truck - RWD 4 Speed w OD
A55 Series Transmissions - Toyota A55 Tercel FWD - A55F 2/4WD
A130 Series Transmissions - A130 Series 3 Speed - A140 Series 4 Speed OD - A240 Series 4 Speed UD - A540E/H, A541E 4 Speed OD
U140 Series Transmissions - Toyota FWD - U140E/F, U240E Series 4 Speed - U150E/U151E Series 5 Speed
U340E Series Transmissions - Toyota FWD - U140E/F, U240E Series 4 Speed - U150E/U151E Series 5 SpeedToyota U340E Series, U341E Series - FWD 4 Speed
Aisin Warner
AW50-40LE/AW60-40LE Transmissions - Aisin Warner AW60-40LE (AF13), AW50-40LE (AF14-20), AW50-42LE/LM
AW55-50SN Transmission - Aisin Warner AW55-50SN (AF33-5) 5 Speed
Volkswagen
010 Transmissions - Volkswagen 010, 087, 089, 090 - FWD 1 Band Type
003 Transmission - Volkswagen 003 - 2 Band Type Rear Transaxle
AG4 Transmissions - Volkswagen 4 Speed FWD Electronic - AG4-095/096/097/098, 01M/01N/01P
Доп. информация: http://ipicture.ru/uploads/080313/JqS462CLd5.jpg
http://ipicture.ru/uploads/080313/bWAw1c9vcR.jpg
Текущее время: 07-Июн 17:58
