JCE Editor + плагины 2.3.4.4
Создавать темы 10-Ноя-2022 09:39 | #1 · Автор
Версия компанента: 2.3.4.4
Версия плагинов: 2013
Год выпуска: 2013
Разработчик: www.joomlacontenteditor.net
Таблетка: не требуется
Требования: joomla 3
Язык: Русский
В версии 2.3.4.4 внесены следующие исправления:
Fixed : Remove Format button
Fixed : Active Line background colour in monokai Source Code theme
Fixed : Cannot drag and drop images around editor in Chrome.
Added : Text filetypes to File Browser PErmitted File Extensions
Fixed : Long Description browser in Image Manager shows all files, not just images
Changelog
2.3.4.3
Fixed : Strict Standards error in the JCE File Browser Quick Icon
Fixed : Error when saving configuration in Joomla 1.5
Fixed : Error that could cause the Save / Cancel buttons to fail when the Editor Profile contains "hgroup" in the Format list.
2.3.4.2
Fixed : First Plugin Parameter tab item not removed when removing plugin from the editor layout.
Fixed : Updates download errors
Fixed : Some javascript files not minified.
Fixed : Update mime types list to include various ogg formats
Fixed : Vertical Align option not visible in Table dialog.
Fixed : Browser spellcheck option not available in IE11
Added : Enter Key behaviour to escape block elements using ALT+Enter and ALT+Up
Changed : Removed ?etag=hash and replaced with ?hash on all javascript / css requests.
Added : Full set of block elements to Format elements list, removed hgroup.
Added : All valid elements to Custom Styles widget divided into new HTML5 categories.
Fixed : Link dialog showing Mixed Selection when only text selected.
Fixed : Editor content area not resized properly when using Toggle Toolbars.
Fixed : Error when switching to fullscreen if first element in the editor is a comment.
Fixed : Allow generic media elements to omit embed and param tags.
2.3.4.1
Fixed : Dialogs not loading correctly when Compress CSS enabled
2.3.4
Fixed : Loading language files on some systems where parse_ini_file is not available.
Changed : Editor Global Configuration is now stored in the JCE Editor Plugin paramters to prevent it being overwritten when saving Component options.
Added : set etag header based on file hash on compressed files to improve browser caching.
Fixed : Installtion error in Joomla 1.5 when copying index.html files
Added : Style Formats widget to create custom options for the Styles list.
Added : Block Formats widget for setting / ordering Format options.
Added : Font Family widget for adding new fonts to the Font Family list.
Changed : Replace use of &version with &etag using file hash or version hash.
Fixed : Improved error display in Updates dialog.
Fixed : Error when searching profiles in Joomla 1.5
Fixed : Parameter value position in Joomla 3.2
Fixed : Added dummy "&file=extension.xml" to updates url to prevent Joomla from adding "/extension.xml"
Fixed : Help dialog display in standalone File Browser dialog.
Changed : Return Custom Colours option to Colorpicker
Changed : Move Paste As Plain Text out of drop-down menu to individual button.
Changed : Disable Google Spellcheck option as the service has been discontinued by Google.
Fixed : Window scrolling when a dialog is open on small screens.
Fixed : Table dialog not showing correct options when editing a cell / row.
Fixed : Ordered / Unordered List detection and conversion when pasting from Word.
Added : Options to set JCE MediaBox default values for popup tab.
Update : Codemirror to 3.1.9
Added : Option to set Source Code Editor font size.
Fixed : Better handling of Geshi code.
Fixed : Error messages not always translated.
Fixed : Double encoding of parameter values in JCE MediaBox popup.
Added : Remove Tags, Keep Tags and Remove By Regular Expression options in Clipboard / Paste parameters.
Added : Option to set a class to the editor body element.
Changed : Use protocol relative URL when inserting Vimeo, Youtube and GoogleMaps.
Fixed : Use seamless attribute for iframes in HTML5 Doctype instead of frameborder
Fixed : Element / Text selection in Link dialog where selection is a block element.
Fixed : Getting / setting Youtube privacy mode when inserting Youtube video.
Fixed : Resizing of editor when "Toggle Toolbars" option is used and editor is hidden in a tab.
Update : TinyMCE 3.5.10 - includes various fixes for IE11
Fixed : Improve support for generic media types
Fixed : Improve support for Bootstrap style icon tags.
Fixed : Improve Footnotes conversion when pasting from Word.
Fixed : Error when editing a JCE MediaBox popup when the rel tag contains a non-standard value.
Fixed : Add video id to Youtube playlist option when loop is enabled.
Fixed : Error in Weblinks and Contact items in Link Browser in Joomla 3.2
Fixed : Error inserting images when Validate HTML is No and span is set as a Prohibited Element.
2.3.3.2
Fixed : loadResultArray error when installing editor on some Joomla 3.1 sites.
Fixed : Error / blank screen when uninstalling editor.
Fixed : Link dialog creating popup links with href="#mce_temp_url"
Fixed : Invalid Path error on drag&drop upload of images with invalid characters in the name.
Fixed : Error -200 changed to "Upload error. The server returned an invalid response."
Fixed : Various button names not displaying correctly.
Fixed : Error when processing audio/video tags if no source tag exists.
2.3.3.1
Fixed : Dialog's don't load when Compress Javascript is enabled.
2.3.3
Changed : Style JCE Administration using Bootstrap
Changed : Only save edited parameters - reduces POST data sent to server and therefore fixes issues saving on servers running the PHP suhosin extension.
Changed : Use javascript to extract font-face and colours from template stylesheets to prevent recursion errors with some stylesheets.
Changed : Remove Custom Colours parameter in Editor Profiles -> Editor Parameters. Custom colours should be added to the template stylesheet from where they will be extracted and displayed in the Template tab of the colour picker.
Changed : File Browser "Search" now searches the entire current folder rather than just filtering the visible list.
Changed : Images will now be inserted without dimensions by default, unless dimensions set are different to the original.
Added : Basic LESS support for editor stylesheets.
Added : Upload Image Placeholders - allows users to upload images into placeholders in content.
Added : Convert local images to placeholders when pasting in content from Word etc.
Added : Twitter Vine aggregator to simplify insertion of Vine videos via the Media Manager, as with Youtube, Vimeo etc.
Fixed : Extra empty rows added to editor layout when saving in Firefox.
Fixed : Show Loading bar when opening Profile for editing.
Fixed : Add data-cfasync="false" to script tags to prevent Cloudflare Rocket Launcher processing.
Fixed : Clean Word Content when pasting as plain text.
Fixed : Double processing of URLs in pasted content.
Fixed : Ordered list conversion when pasting from Word etc.
Fixed : Allow for custom media types in object tag, eg: video/youtube
Fixed : Remove html indent when toggling editor as it was removing whitespace in pre tags.
Fixed : Make Cut/Copy/Paste shortcut labels platform specific, eg: CTRL+V to CMD+V on Mac
Fixed : Check extension xml files are valid before processing.
Fixed : Prevent multiple classnames from being removed when editing table/cell/row
Fixed : Firefox bug where image is opened in a new window if dropped onto itself
Fixed : Fix some issues when inserting data into the editor from external dialogs.
Fixed : Table cell selection when using the right-click context menu.
Fixed : Current element selection when updating the table.
Fixed : Invalid html of pagebreak hr tag.
Fixed : Include article language when processing Content link in Link dialog.
Fixed : Update validation of wmv mimetype to include it as video/x-ms-asf
Fixed : Allow links to be created on inline html tags, eg: , etc.
Fixed : Cookie not stored when directory changed in File Browser.
Fixed : Add allowfullscreen attribute for iframes
Fixed : Error when renaming folders.
Fixed : Search/Replace issues in Code View.
Fixed : Fix processing of geshi code
Fixed : Menu links to "secure" menu items now set as https links.
Fixed : Close Rename dialog after warning when renaming files/folders in File Browser.
2.3.2.4
Added : Option to pad empty table cells with a (on by default)
Added : Various work-arounds to prevent bootstrp icon code from being removed.
Added : "Update All" checkbox in Updates dialog.
Changed : Clipboard "Strip Class Attributes" option now a simple Yes / No option.
Chaned : CODE and SAMP Format options are now applied as inline.
Fixed : Search / Replace dialog not working.
Fixed : Cannot create file links on some systems.
Fixed : Cannot create new tables rows after merging in Safari.
Fixed : Options removed when creating popup links to flv files with the Media Manager.
Fixed : Some empty paragraphs not removed when pasting from Word.
Fixed : "Remove Attributes" Clipboard option not working as expected.
Fixed : INVALID MIMETYPE error when uploading docx files.
2.3.2.3
Fixed : Colourpicker dialog blank on some systems
Fixed : Allow backslash in file paths (WAMP, IIS)
Fixed : Updating FLV in Media Manager would remove some options.
Fixed : Cursor jumping when inserting table, pagebreak, anchor in IE8
Fixed : ppt, xls files giving Inavlid Mimetype error on upload.
Fixed : Use of source tags in video/audio if more than one source url.
2.3.2.2
Fixed : Error when importing profile.
Fixed : Colorpicker colour not applied in Font Text Colour or Font Background Colour.
2.3.2.1
Fixed : Toolbar icons not showing when editor Compression options are activated.
Fixed : Custom Character description.
2.3.2
Fixed : Error saving flash / iframe elements
Fixed : Filesystem selection in parameters.
Fixed : Remove filesize check when validating uploaded file (causes errors on some systems)
Fixed : Menu links not returning sub-menus in Joomla 1.5
Fixed : Class stripping when pasting from Word etc.
Fixed : Invalid File Type error when uploading htm/html files.
Fixed : Remove version check for JCE MediaBox Popups causing blank page in link dialog in some instances.
Fixed : Update powerpoint mimetype validation.
Fixed : Use src attribute instead of nested element if single source in
Fixed : Issues with MediaBox parameteres when editing popup.
Fixed : Errors in Joomla 3 when using JParameter. Changed to JRegistry.
Fixed : Strict Standards errors caused by backwards compatbility issues.
Update : Codemirror, JQuery, JQuery UI
Added : Dialog button icons due to JQuery UI improvements.
Added : Footnote processing on Paste
Fixed : List conversion on Paste
Fixed : Keep in td elements.
Fixed : Use utf-8 space if Encoding set to UTF-8
Fixed : Colorpicker now shows theme and custom colours.
Update : Improve Help dialog layout with collapsible and draggable frames.
Update : Improve Updates dialog layout
Fixed : Handling of UNC paths on IIS systems.
Added : Postgesql support (Joomla 3 only)
Added : Editor and Plugin version numbers added to script / stylesheet URLs to prevent use of cached files from previous versions.
Fixed : Styles removed from some elements when using backspace in Webkit browsers.
Update : Updated input filtering.
Changed : Process @import and googlefont rules for Font List using javascript instead of PHP.
Fixed : Some Media Player options not applied in Media Manager.
Fixed : Allow for empty usergroups in Editor Profiles if a User is set.
Changed : Optimize png and gif files.
Fixed : Add task=weblink.go to all J2.5 weblink items
Fixed : Fix serialization of embed flash attributes
Fixed : Link selector causing links to be inserted with an href of #mce_temp_url#
Fixed : Allow for additional query data on media URLs
Fixed : Image source of images uploaded using drag & drop on IIS servers.
Fixed : Error message when attempting to update a table with a border value set.
Fixed : Float style removed from image when adding a link to it in Webkit.
Fixed : 404 error in Updates dialog when triggered from "Updates Available" link.
Added : Option to set File Browser dialog width and height.
Fixed : Cleanup after add-on update / install.
Fixed : Extension install improvements.
Fixed : Install errors in Joomla 1.5 due to incorrect temp folder path
Added : Attempt to fix Profile saving when server is running suhosin extension.
Added : Page loader in Profiles list and edit screens.
Fixed : Gzip encoding check in script packer.
2.3.1
Fixed : Styles, Format etc. lists not translated if no language pack installed and Admin language is not english.
Fixed : Editor doesn't load if a user is assigned to the Profile that is not in one of the selected User Groups.
Fixed : Save and Save & Close buttons not availble in Preferences dialog in Joomla! 1.5
Fixed : Package and temp folder not removed after plugin install.
Fixed : Various css fixes for the "Mission Control" admin template.
Fixed : Editor would fail to load in K2 in some instances if an Extra Field was enabled.
Описание:
JCE Editor набор инструментов для CMS Joomla, предоставляющий возможность создавать и редактировать контент в соответствии с вашими требованиями.
Просьба перекачать, обновил плагины.
Текущее время: 06-Июл 01:44
